[Qgis-user] Print composer crash
    Andreas Neumann
    a.neumann at carto.net
    Tue Jun 23 00:07:05 PDT 2015
Hi Joris,
I just tested PDF and printing of very large output (1.5x1.2m) several
times one after the other. I tested both on Windows 7, 64bit and on
Ubuntu 64bit and there was no crash or problem. I tested with or without
raster and both worked fine.
Can you share your project so we can try to replicate the issue? You'd
have to open a bug report and make your project and data available
somewhere to download.
Andreas
On 22.06.2015 15:04, Joris Hintjens wrote:
> Hello,
> since recently, I cannot save a print without crashing QGIS.
> I tried this both on windows7 and OX Yosemite:
> Saving a map via print composer (in jpg OR in pdf!): once I click the
> “save” button, the print composer goed white and stalls.
> It started wit trying to save to a A0 paper format. So I reduced to
> smaller paper size, but still the problem persists. I am now back to
> A4 format, with a 300 DPI resolution, but still, no improvement.
> I can use my print model only 1 time, but for the second map, the
> composer crashes. I can work again when I make a new print template.
> Screen record of proces is here:
> https://youtu.be/iBXwC-ebubs
> When I close the composer and go back to main window to close and
> restart; I get a crash alert on quit. Crash report is stored here:
> _https://www.dropbox.com/s/z8vuw45o3wqxzse/crashReport.txt?dl=0_
> thanks for any comment or idea to solve this annoying hickup.
> Joris
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/88be5207/attachment.html>
