[Qgis-user] Vector area calculation
    Fred Lali
    lalifred at gmail.com
    Tue Jun 23 02:59:50 PDT 2015
Members, I need help or guidance on how to calculate the polygon area, may be  I'm doing is a wrong way.
I toggle edit tab i.e the pencil icon and i use vectors geometry tools to export/add geometry columns. But it gives me area as a decimal
For God and My Country
Consultant in: GIS,Forestry and Environment @ Earth Consult(U) Ltd.
CCRP GIS Support-Uganda
(The MCKNIGHT Foundation)
Rotarian at RC. Bweyogerere Namboole
Mob: 0772/0752-841118
Sent from Lumia Windows phone
-----Original Message-----
Sent: 23/06/2015 12:05
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Transparency for vector symbol layers
Hello Andreas,
Thank you very much for your complete answer.
Actually, I reached my goal using rule based renderers.
Regards,
Benoît
Hi Benoit,
It depends. Yes - you can mix transparent and opaque features. For each color you can also set the opacity/transparency value.
However, if two features overlap and you use transparency on the feature level, you can see the features shine through - whereas when the transparency would be on the symbol level (which isn't implemented yet in QGIS) you would first composite all elements in a symbol level and then apply the opacity on the whole group. See http://www.w3.org/TR/2011/REC-SVG11-20110816/masking.html#ObjectAndGroupOpacityProperties for the difference. In http://www.w3.org/TR/2011/REC-SVG11-20110816/images/masking/opacity01.png - if you look at the bottom row of circles - the second pair of circles has the opacity on the group of two circles, whereas the third pair has opacity on every single element. I hope you can see the difference.
It would be very cool if QGIS could have a more fine-grained opacity - new opacity on symbol level and new opacity on a whole group of layers. It would make the cartographic options even better ;-)
Andreas
On 19.06.2015 16:40, Benoît Laurent wrote:
Hello,
I noticed this feature request : https://hub.qgis.org/issues/3438.
Is it possible to have semi-transparent and opaque features within the same layer ?
Best regards,
Benoît
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
https://www.avast.com/antivirus
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
Benoît LAURENT Consultant Optimisation
9, rue Alexandre Fleming, 49066 Angers CEDEX
 +33 (0)6 28 03 81 32        blaurent at heurisis.eu
 +33 (0)9 54 30 41 14      www.heurisis.eu
Visitez le site www.optiscolaire.fr
 Avant d’imprimer ce mail, pensez à l’environnement
www.avast.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/c3283f75/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/c3283f75/attachment.jpg>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/c3283f75/attachment.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/c3283f75/attachment-0001.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/c3283f75/attachment-0002.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/c3283f75/attachment-0003.gif>
