[Qgis-user] Transparency for vector symbol layers
Benoît Laurent
blaurent at heurisis.eu
Tue Jun 23 02:05:10 PDT 2015
Hello Andreas,
Thank you very much for your complete answer.
Actually, I reached my goal using rule based renderers.
Regards,
Benoît
> Hi Benoit,
> It depends. Yes - you can mix transparent and opaque features. For
> each color you can also set the opacity/transparency value.
> However, if two features overlap and you use transparency on the
> feature level, you can see the features shine through - whereas when
> the transparency would be on the symbol level (which isn't implemented
> yet in QGIS) you would first composite all elements in a symbol level
> and then apply the opacity on the whole group. See
> http://www.w3.org/TR/2011/REC-SVG11-20110816/masking.html#ObjectAndGroupOpacityProperties
> for the difference. In
> http://www.w3.org/TR/2011/REC-SVG11-20110816/images/masking/opacity01.png
> - if you look at the bottom row of circles - the second pair of
> circles has the opacity on the group of two circles, whereas the third
> pair has opacity on every single element. I hope you can see the
> difference.
> It would be very cool if QGIS could have a more fine-grained opacity -
> new opacity on symbol level and new opacity on a whole group of
> layers. It would make the cartographic options even better ;-)
> Andreas
> On 19.06.2015 16:40, Benoît Laurent wrote:
>> Hello,
>> I noticed this feature request : https://hub.qgis.org/issues/3438.
>> Is it possible to have semi-transparent and opaque features within
>> the same layer ?
>> Best regards,
>> Benoît
>> L'absence de virus dans ce courrier électronique a été vérifiée par
>> le logiciel antivirus Avast.
>> https://www.avast.com/antivirus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Signature_Benoit_Laurent
Heurisis <http://www.heurisis.eu>
Benoît LAURENT Consultant Optimisation
9, rue Alexandre Fleming, 49066 Angers CEDEX
Portable +33 (0)6 28 03 81 32 e-mail : blaurent at heurisis.eu
<mailto:blaurent at heurisis.eu>
tel : +33 (0)9 54 30 41 14 site : www.heurisis.eu <http://www.heurisis.eu/>
Visitez le site www.optiscolaire.fr <http://www.optiscolaire.fr>
éco : Avant d’imprimer ce mail, pensez à l’environnement
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/82817315/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/82817315/attachment.jpg>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/82817315/attachment.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/82817315/attachment-0001.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/82817315/attachment-0002.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/82817315/attachment-0003.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150623/82817315/attachment-0004.gif>
