[Qgis-user] [Qgis-developer] DXF/DWG import requirements document
Siki Zoltan
siki at agt.bme.hu
Tue Jun 23 10:26:46 PDT 2015
Dear Andreas,
beside "Import of layer names as attributes" I would prefer
1. setting layer filter in the import dialog (e.g. as a regexp or a
selection list from the available CAD layers), unselected layers are
skipped in input.
It is not clear for me if the layer name rules can be used for this
purpose.
2. import each CAD layer into separate QGIS layers by feature type (point,
annotation, polyline, polygon), it could be a checkbox in the import
dialog.
Optionally during the import polygon layers sould be cheched for islands
(polygons inside other polygon) and remove the area of islands from the
container polygon.
Regards,
Zoltan
On Tue, 23 Jun 2015, Andreas Neumann wrote:
> Hi,
> To all who have an interest in contributing to a DXF/DWG import
function in
> QGIS:
> I have started working on a requirements document - you can view it here:
> https://docs.google.com/a/qgis.org/document/d/1NJv1lwd5TnWdV-fTuW7g5ts1O8r3vb46xYeAIQ_BwGw/edit?usp=sharing
> If you want to contribute to the document, please send me your gmail account
> so I can give you write access.
> After a couple of days (maybe 1.5-2 weeks) we can hopefully finish this
> document and ask for a quote. I will then ask again for organizations or
> companies who can contribute financially.
> Thank you in advance for your support!
> Andreas
> Qgis-developer mailing list
