[Qgis-user] [Qgis-developer] DXF/DWG import requirements document
Andreas Neumann a.neumann at carto.net
Tue Jun 23 13:10:22 PDT 2015
Hi Zoltan,
I added these two requirements in the document. However, with the new
legend options introduced in QGIS 2.8 you can easily toggle the
visibility of classes or rules or delete certain rules - so I am not
100% convinced if this option is really necessary.
Thanks for your reply!
Andreas
On 23.06.2015 19:26, Siki Zoltan wrote:
> Dear Andreas,
> beside "Import of layer names as attributes" I would prefer
> 1. setting layer filter in the import dialog (e.g. as a regexp or a
>    selection list from the available CAD layers), unselected layers are
>    skipped in input.
>    It is not clear for me if the layer name rules can be used for this
>    purpose.
> 2. import each CAD layer into separate QGIS layers by feature type
> (point,
>    annotation, polyline, polygon), it could be a checkbox in the import
>    dialog.
> Optionally during the import polygon layers sould be cheched for
> islands (polygons inside other polygon) and remove the area of islands
> from the container polygon.
> Regards,
> Zoltan
> On Tue, 23 Jun 2015, Andreas Neumann wrote:
>> Hi,
>> To all who have an interest in contributing to a DXF/DWG import
> function in
>> QGIS:
>> I have started working on a requirements document - you can view it
>> here:
>> https://docs.google.com/a/qgis.org/document/d/1NJv1lwd5TnWdV-fTuW7g5ts1O8r3vb46xYeAIQ_BwGw/edit?usp=sharing
>> If you want to contribute to the document, please send me your gmail
>> account so I can give you write access.
>> After a couple of days (maybe 1.5-2 weeks) we can hopefully finish
>> this document and ask for a quote. I will then ask again for
>> organizations or companies who can contribute financially.
>> Thank you in advance for your support!
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
