[Qgis-user] problem with dxf2shp
Carlos López PSIG
carlos.lopez at psig.es
Fri Jun 26 02:09:18 PDT 2015
Hi Daniel,
I have the same problems....
Sometimes, when I need elevation attribute I work with geobide [1] program,
geoconverter [2]
[1] http://www.geobide.es/
[2] http://www.geobide.es/geoconverter/
This program is not open source, but it's free!
Best regards,
* <http://www.psig.es>*
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2015-06-25 23:43 GMT+02:00 Daniel Camilo Largo Gaviria <
daniel.largo at gmail.com>:
> Hi,
> i have a problem with QGIS. I need to convert dxf to shp. When i use
> dxf2shp function i can´t to see the attribute, for example:
> i need to convert contours (topography) of dxf to shp, but, the attribute
> of height don't appears.
> Someone know how convert and import full attribute?
> tks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150626/c4af3ff9/attachment.html>
