[Qgis-user] problem with dxf2shp
Lens Paul
paul.lens at gmx.com
Fri Jun 26 09:24:31 PDT 2015
Hi Daniel,
I have not made that kind of conversion for a while now, probably back
to QGIS 1.5.
At that time, dxf2shp didn't keep any 3D information indeed.
- v.in.dxf in GRASS worked well;
- if you have a raster, extracting contours with the QGIS "interpolate"
command was succesfull too (a workaround could then be to create a
raster using your contours lines, and then back to the contour lines
with interpolate).
Hope this helps,
Paul
Le 25/06/2015 23:43, Daniel Camilo Largo Gaviria a écrit :
> Hi,
> i have a problem with QGIS. I need to convert dxf to shp. When i use
> dxf2shp function i can´t to see the attribute, for example:
> i need to convert contours (topography) of dxf to shp, but, the
> attribute of height don't appears.
> Someone know how convert and import full attribute?
> tks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150626/43b37e7b/attachment.html>
