[Qgis-user] Default values in form
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Jun 26 04:57:46 PDT 2015
PS: I would prefer to work on a holistic approach instead of adding
individual tickets. To prevent the user interface from getting even more
cluttered by letting it grow organically. It always makes me want to
scream when I see the fields configuration dialog. Until I realize that
it was actually also me adding a lot of stuff in there.
Therefore, please add comments and improvements to this document:
https://github.com/m-kuhn/QGIS-Enhancement-Proposals/blob/fields-and-forms-redesign/QEP-Fields-and-forms-redesign.rst#31-fields
and the associated discussion
https://github.com/qgis/QGIS-Enhancement-Proposals/pull/13
Cheers
Matthias
On 06/26/2015 01:53 PM, Matthias Kuhn wrote:
> Hi,
> Yes, tooltips that show the comments would also be great. It would be
> nice to show
> * the database comments (if supported by the backend) as default
> * allow to override it in the configuration
> Default values from expressions would also be a great addition. I
> think it would be better to define it directly on the field (and not
> on its widget). This way you can later turn the widget into something
> else (e.g. from text to range) without reconfiguring the default
> value. And it should have defaults for the defaults :) being read from
> the database where possible.
> Cheers,
> Matthias
> On 06/26/2015 01:05 PM, Blumentrath, Stefan wrote:
>> Hi,
>> I am about to file a ticket for this. Another thought in this context:
>> When defining “default values” it would be splendid if one could use
>> variables (e.g. %USER% or expressions like in the field calculator or
>> Relation Reference widget). What do you think?
>> The latter could probably go into a new widget type "Calculated"?
>> Another thing in this context could be adding the possibility do
>> define “Mouse-over effects” in order to help understanding attribute
>> content better (e.g. Units, backgrounds, how to measure in the
>> field…)?! Lables are not allways sufficient, but maybe the GUI gets
>> too fidgety?
>> Should a request for this go into separate tickets?
>> Cheers
>> Stefan
>> *From:*qgis-user-bounces at lists.osgeo.org
>> [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *didier peeters
>> *Sent:* 26. juni 2015 12:36
>> *To:* qgis-user
>> *Subject:* Re: [Qgis-user] Default values in form
>> Hello Mathias,
>> this would be great !
>> Additionally, this makes me think of another possible enhancement:
>> when displaying a picture in a form tab, it could be nice to hide the
>> label and path/url to the file, which is most of the time useless.
>> Do I need to do anything more to make these suggestions ?
>> Didier
>> Le 26 juin 2015 à 12:07, Matthias Kuhn <matthias.kuhn at gmx.ch
>> <mailto:matthias.kuhn at gmx.ch>> a écrit :
>> I think this would fit into the area of this QEP:
>> It could be added to the list "Information about fields" next to
>> "constraints".
>> Any feedback on it is welcome.
>> Matthias
>> On 06/26/2015 11:35 AM, Paolo Cavallini wrote:
>> Agreed, an important improvement. Please open a ticket if not
>> already there.
>> All the best.
>> Il 26 giugno 2015 08:16:32 GMT+00:00, "Blumentrath, Stefan"
>> <Stefan.Blumentrath at nina.no>
>> <mailto:Stefan.Blumentrath at nina.no> ha scritto:
>> Hei Didier,
>> I guess you could use a python init function for the form in order to define "default values" (see: http://nathanw.net/2011/09/05/qgis-tips-custom-feature-forms-with-python-logic/).
>> However, sounds like a useful enhancement of the Custom form functionality (at least I would be interested too)...
>> Cheers
>> Stefan
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org <mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of didier peeters
>> Sent: 26. juni 2015 10:08
>> To: qgis-user
>> Subject: [Qgis-user] Default values in form
>> Hello,
>> Simple question : is there a way to set a default value for an attribute in QGis ?
>> I have Postgis layers in QGis in which I’m inserting or updating data, and I would like that some fields would be filled automatically unless I fill
>> them myself. Well that’s the definition of a default value, and I don’t think that using layers stored in Postgis would make any difference.
>> Thanks
>> Didier
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> http://faunalia.eu <http://faunalia.eu/>/
>> Sent from mobile, sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150626/0b9ef44d/attachment.html>
