[Qgis-user] mrsid qgis 2.8 and ubuntu 14.04
Chris House
housec01 at gmail.com
Fri Jun 26 10:58:40 PDT 2015
i did try both of the build methods and neither worked. I get "command not
found" for both.
I would prefer a different format but I'm unaware of another file type that
can compress as well as mrsid (usable file sizes) that cover as much
territory (>200km2)
Thanks
Chris
On Fri, Jun 26, 2015 at 1:51 PM, James Keener <jim at jimkeener.com> wrote:
> I've not used it as a gdal plugin and in the past have simply converted
> my data into a more standard format:
> http://jimkeener.com/posts/orthoimagery
> Have you followed the steps you've linked to? Did either the
> gdal-build-mrsid or gdal-mrsid-build work?
> Jim
> On 06/26/2015 01:43 PM, Chris House wrote:
> > Hi all,
> > I'm trying to find some updated instructions for adding MrSid support
> > for QGIS 2.8 on Ubuntu 14.04. I started following the instructions from
> > here:
> > https://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid
> > However, I'm hung up on the instructions where you do the build. I
> > downloaded the following mrsid sdk from Lizardtech and extracted it.
> > MrSID_DSDK-9.1.0.4045-linux.x86-64.gcc44.tar.gz
> > The readme specifically says "no real installation is necessary"
> > Can someone point me to some updated instructions on how to get mrsid
> > support in QGIS 2.8?
> > Thanks!
> > Chris
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150626/c14f82ab/attachment.html>
