[Qgis-user] mrsid qgis 2.8 and ubuntu 14.04
Andrew
amcaninch at gmail.com
Fri Jun 26 11:12:13 PDT 2015
Chris,
I am not an expert but I think that those instructions do not work because
the plugin "libgdal-mrsid-src" is no longer in the repository. Have you
looked at these instructions from a couple years ago?
http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-td5090885.html
I never got around to trying it since I dont use mrsid images very often
and when I do I just do it on my windows machine, but the instructions are
more up to date and dont rely on the plugin.
Andrew
On Fri, Jun 26, 2015 at 10:58 AM, Chris House <housec01 at gmail.com> wrote:
> i did try both of the build methods and neither worked. I get "command not
> found" for both.
> I would prefer a different format but I'm unaware of another file type
> that can compress as well as mrsid (usable file sizes) that cover as much
> territory (>200km2)
> Thanks
> Chris
> On Fri, Jun 26, 2015 at 1:51 PM, James Keener <jim at jimkeener.com> wrote:
>> I've not used it as a gdal plugin and in the past have simply converted
>> my data into a more standard format:
>> http://jimkeener.com/posts/orthoimagery
>> Have you followed the steps you've linked to? Did either the
>> gdal-build-mrsid or gdal-mrsid-build work?
>> Jim
>> On 06/26/2015 01:43 PM, Chris House wrote:
>> > Hi all,
>> > I'm trying to find some updated instructions for adding MrSid support
>> > for QGIS 2.8 on Ubuntu 14.04. I started following the instructions from
>> > here:
>> > https://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid
>> > However, I'm hung up on the instructions where you do the build. I
>> > downloaded the following mrsid sdk from Lizardtech and extracted it.
>> > MrSID_DSDK-9.1.0.4045-linux.x86-64.gcc44.tar.gz
>> > The readme specifically says "no real installation is necessary"
>> > Can someone point me to some updated instructions on how to get mrsid
>> > support in QGIS 2.8?
>> > Thanks!
>> > Chris
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150626/42129a13/attachment.html>
