[Qgis-user] Live DVD advice
James Keener
jim at jimkeener.com
Sat Jun 27 16:52:51 PDT 2015
Could you use QGIS Server? It'd take a qgs file and the data it needs
(which can be any input type QGIS uses, including shapefiles and
spatialite dbs along with PostGIS).
Jim
On 06/27/2015 07:46 PM, Brent Wood wrote:
> Hi,
> I'm looking to build a LiveDVD/USB key with QGIS, OSM base layer and web
> services for New Zealand.
> Our road & topo data is very up to date in OSM, and we have numerous
> government (central, regional & local) agencies and others providing
> data via OGC services, so I'm hoping the system will have embedded OSM,
> and pre-loaded OGC servers to connect to, as well as some QGIS plugins
> specific to New Zealand.
> The disk/key is intended for schools & demonstrations showing FOSS, FOSS
> GIS, Open Data and Open Standards, focused on NZ data.
> Some years ago I built a laptop system demo'ed at several local schools
> which worked OK, with mapserver serving OSM via WMS direct from Postgis.
> NZ is small enough that the data could be rendered dynamically from the
> vector data in a reasonably interactive system.
> I can't reasonably use Postgis on a read only filesystem, and all the
> later guides assume that tiles will be used. Does anyone have any advice
> as to how I might best do this?
> Thanks,
> Brent Wood
> Qgis-user mailing list
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150627/c28078c1/attachment.sig>
