[Qgis-user] Live DVD advice
    Brent Wood
    pcreso at pcreso.com
    Sat Jun 27 17:13:57 PDT 2015
Thanks James,
I have looked at http://docs.qgis.org/2.8/en/docs/user_manual/working_with_ogc/ogc_server_support.html?highlight=server
which seems like it would work - but I'd still need to avoid Postgis as the data source (read only filesystem) and sort out the rendering styles for use with QGIS - it may be possible to export the OSM Postgis tables as shapefiles & use those as the data source, but I don't know how to go about adapting the rendering styles, which is a large part of the value of OSM - data plus style.
Cheers,
  Brent
 To: Brent Wood <pcreso at pcreso.com>; Qgis-user List <qgis-user at lists.osgeo.org>; Mapserver-users <mapserver-users at lists.osgeo.org>; OSGeo Discussions <discuss at lists.osgeo.org>; Nzopengis <nzopengis at googlegroups.com>; Live-demo <live-demo at lists.osgeo.org>
 Sent: Sunday, June 28, 2015 11:52 AM
 Subject: Re: [Qgis-user] Live DVD advice
Could you use QGIS Server?  It'd take a qgs file and the data it needs
(which can be any input type QGIS uses, including shapefiles and
spatialite dbs along with PostGIS).
Jim
On 06/27/2015 07:46 PM, Brent Wood wrote:
> Hi,
> I'm looking to build a LiveDVD/USB key with QGIS, OSM base layer and web
> services for New Zealand.
> Our road & topo data is very up to date in OSM, and we have numerous
> government (central, regional & local) agencies and others providing
> data via OGC services, so I'm hoping the system will have embedded OSM,
> and pre-loaded OGC servers to connect to, as well as some QGIS plugins
> specific to New Zealand.
> The disk/key is intended for schools & demonstrations showing FOSS, FOSS
> GIS, Open Data and Open Standards, focused on NZ data.
> Some years ago I built a laptop system demo'ed at several local schools
> which worked OK, with mapserver serving OSM via WMS direct from Postgis.
> NZ is small enough that the data could be rendered dynamically from the
> vector data in a reasonably interactive system.
> I can't reasonably use Postgis on a read only filesystem, and all the
> later guides assume that tiles will be used. Does anyone have any advice
> as to how I might best do this?
> Thanks,
> Brent Wood
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150628/5600d858/attachment.html>
