[Qgis-user] Labeling in Composer with QGIS 2.8
    Claire BERGUER
    berguer.c at la-diege.fr
    Fri Mar  6 03:09:19 PST 2015
Thanks' for your answer.
Actually it's seems just to be a problem from conversion to the new version.
I cannot replicate the bug  with a new project, created on version 2.8.
So, I will not fil a ticket yet. Will see if I can better identify the bug's conditions.
Claire
-----Message d'origine-----
De : Sandro Santilli [mailto:sandro.santilli at gmail.com] De la part de Sandro Santilli
Envoyé : jeudi 5 mars 2015 17:15
À : Claire BERGUER
Cc : Qgis-user at lists.osgeo.org
Objet : Re: [Qgis-user] Labeling in Composer with QGIS 2.8
On Thu, Mar 05, 2015 at 02:48:56PM +0000, Claire BERGUER wrote:
> Hello,
> I have a problem with the new version 2.8.
> As I "rotate" the map in the print composer, the labels will not appear anymore.
> Is that normal? It's work fine when the map don't have any rotation.
It's _not_ normal, but you're not the first one reporting it.
Only, I'm afraid nobody filed a ticket for this yet.
IIRC, the previous reporter found that saving the project and re-opening it worked around the bug (but I could be wrong).
In any case, I'd recommend filing a ticket with all the informations (and please include the "rotation" tag).
 http://hub.qgis.org/projects/quantum-gis/issues
Thank you.
--strk;
