[Qgis-user] Identify feature - how to deselect 2.8
Werner Macho
werner.macho at gmail.com
Sun Mar 8 01:09:46 PST 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Again!
The "Identify Results" Dock has got a button on top that is called
"Clear Results" on mouseover.
That now works for me every time (but it took me also some time to
find it - but once you got it it is clear that it belongs there)
As the "Identify Results" Dock is automatically focused when you use
the tool it should not be a problem any more.
regards
Werner
On 03/08/2015 10:01 AM, Lene Fischer wrote:
> When I select the AutoOpen Form. The Deselect don´t work any longer
> – and I´m not able to delete the selection – not even for
> deselected layer.
> And now it create a minidump if I remove the layer…
> I think I must create a bugreport.
> Regards
> Lene
> *Fra:*Nathan Woodrow [mailto:madmanwoo at gmail.com] *Sendt:* 8. marts
> 2015 09:37 *Til:* Lene Fischer; Werner Macho;
> qgis-user at lists.osgeo.org *Emne:* Re: [Qgis-user] Identify feature
> There should be a unselect button on the dock with the info.
> Nathan
> On Sun, 8 Mar 2015 6:33 pm Lene Fischer <lfi at ign.ku.dk
> <mailto:lfi at ign.ku.dk>> wrote:
> Urff- :-O Thanks for you quick reply - Hope there will be another
> workaround in next release :-) Regards Lene
> -----Oprindelig meddelelse----- Fra:
> qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>
> [mailto:qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>] På vegne af Werner
> Macho Sendt: 8. marts 2015 09:23 Til: qgis-user at lists.osgeo.org
> <mailto:qgis-user at lists.osgeo.org> Emne: Re: [Qgis-user] Identify
> Hi Lene!
> Good Question, First workaround: Enable "Auto open form" and use
> identify .. If you close the popped up auto form window the red
> markers are also gone.
> regards Werner
> On 03/08/2015 09:09 AM, Lene Fischer wrote:
>> Hi,
>> I have now tried the new 2.8 Identify Feature - it is
>> brilliant!!!
>> But how do I "deselect" / remove the red selections.
>> Regards
>> *Lene Fischer*
>> Associate Professor
>> *Department of Geosciences and Natural Resource Management*
>> University of Copenhagen
>> MOB +45 40115084
>> lfi at ign.ku.dk <mailto:lfi at ign.ku.dk> <mailto:lfi at ign.ku.dk
>> cid:image001.gif at 01D03029.2F3EC6A0
>> _______________________________________________ Qgis-user mailing
>> list Qgis-user at lists.osgeo.org
>> <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> list Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
iEYEARECAAYFAlT8EdoACgkQDAH1YiCxBgkBJACgiSMnlipvFsBbqO5+UN0NL7+v
B7cAn37GCC00oeXwnOOWN5PRrxENJZ2q
=oon0
-----END PGP SIGNATURE-----
