[Qgis-user] Identify feature - how to deselect 2.8
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Sun Mar 8 03:04:04 PDT 2015
Ok ---
Steps to reproduce the bug :
1. Create a project with a single polygon layer
2. Click on a polygon with "identify features" tool and the "Auto open
forms" in dialogue "Identify Results" activated. QGIS will show a
"Feature attributes" dialogue as expected.
3. Click on another polygon. You get a new "Feature attributes"
dialogue for the new selected polygon, but the previous "Feature
attributes" doesn't disappear (Is this a bug or a new feature ? ).
You can see the "Feature attributes" dialogues accumulate in the
windows task bar besides the QGIS icon.
If you don't activate "Auto open forms", QGIS works as expected
(like in previous versions of QGIS).
If you have "Auto open forms" activated and manually close the
"Feature attributes" dialogues using the windows task bar, the
dialogues *and* their associated selection disappear, one by one.
4. If you click on the "Clear results" button in dialogue "Identify
Results" the accumulated selected features and their associated
"Feature attributes" dialogues is *not* removed.
5. If you make the layer with the selected objects *invisible*, the
selection is *not* removed.
6. If you *remove* the layer with the selected objects from the
project, QGIS crashes.
Regards
Bo Victor Thomsen
AestasGIS
Denmark
Den 08-03-2015 kl. 10:09 skrev Werner Macho:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Again!
> The "Identify Results" Dock has got a button on top that is called
> "Clear Results" on mouseover.
> That now works for me every time (but it took me also some time to
> find it - but once you got it it is clear that it belongs there)
> As the "Identify Results" Dock is automatically focused when you use
> the tool it should not be a problem any more.
> regards
> Werner
> On 03/08/2015 10:01 AM, Lene Fischer wrote:
>> When I select the AutoOpen Form. The Deselect don´t work any longer
>> – and I´m not able to delete the selection – not even for
>> deselected layer.
>> And now it create a minidump if I remove the layer…
>> I think I must create a bugreport.
>> Regards
>> Lene
>> *Fra:*Nathan Woodrow [mailto:madmanwoo at gmail.com] *Sendt:* 8. marts
>> 2015 09:37 *Til:* Lene Fischer; Werner Macho;
>> qgis-user at lists.osgeo.org *Emne:* Re: [Qgis-user] Identify feature
>> There should be a unselect button on the dock with the info.
>> Nathan
>> On Sun, 8 Mar 2015 6:33 pm Lene Fischer <lfi at ign.ku.dk
>> <mailto:lfi at ign.ku.dk>> wrote:
>> Urff- :-O Thanks for you quick reply - Hope there will be another
>> workaround in next release :-) Regards Lene
>> -----Oprindelig meddelelse----- Fra:
>> qgis-user-bounces at lists.osgeo.org
>> <mailto:qgis-user-bounces at lists.osgeo.org>
>> [mailto:qgis-user-bounces at lists.osgeo.org
>> <mailto:qgis-user-bounces at lists.osgeo.org>] På vegne af Werner
>> Macho Sendt: 8. marts 2015 09:23 Til: qgis-user at lists.osgeo.org
>> <mailto:qgis-user at lists.osgeo.org> Emne: Re: [Qgis-user] Identify
>> Hi Lene!
>> Good Question, First workaround: Enable "Auto open form" and use
>> identify .. If you close the popped up auto form window the red
>> markers are also gone.
>> regards Werner
>> On 03/08/2015 09:09 AM, Lene Fischer wrote:
>>> Hi,
>>> I have now tried the new 2.8 Identify Feature - it is
>>> brilliant!!!
>>> But how do I "deselect" / remove the red selections.
>>> Regards
>>> *Lene Fischer*
>>> Associate Professor
>>> *Department of Geosciences and Natural Resource Management*
>>> University of Copenhagen
>>> MOB +45 40115084
>>> lfi at ign.ku.dk <mailto:lfi at ign.ku.dk> <mailto:lfi at ign.ku.dk
>>> cid:image001.gif at 01D03029.2F3EC6A0
>>> _______________________________________________ Qgis-user mailing
>>> list Qgis-user at lists.osgeo.org
>>> <mailto:Qgis-user at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> list Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.15 (GNU/Linux)
> iEYEARECAAYFAlT8EdoACgkQDAH1YiCxBgkBJACgiSMnlipvFsBbqO5+UN0NL7+v
> B7cAn37GCC00oeXwnOOWN5PRrxENJZ2q
> =oon0
> -----END PGP SIGNATURE-----
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150308/410e6d7b/attachment.html>
