[Qgis-user] QGIS Export Map
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Mar 8 20:24:02 PDT 2015
Remove all layers exept the openlayers layers. Zoom in and use the "save as image" option ( under project I think). Pan again and take another snapshot. All images will be save and georeferenced with a world file and you can then reload them in your project. Make sure you cite your sources.
Nicolas Cadieux M.Sc.
Le 2015-03-08 22:56, "lpalao [via OSGeo.org]" <ml-node+s1560n5192183h34 at n6.nabble.com> a écrit :
Hi QGIS users, I have a bit of a problem. I am using Open Layers Google Physical Layer as background of my other layers. When I layout my maps in Print Composer, the layers are well aligned. But when I export it to JPEG or PNG the output product is misaligned. I allow on-the-fly option when the layer from Open Layers were added. So, I thought this might be causing the issue. But then I transformed all of my layers to EPSG 3857 but still problem persist. Can you help me with this? I am using QGIS 2.6.1 Brighton installed via OSGeo. Thanks, -Leo
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/QGIS-Export-Map-tp5192183.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Export-Map-tp5192183p5192186.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150308/23752258/attachment.html>
