[Qgis-user] QGIS Export Map
Carlos Cerdán
sig.upagu at gmail.com
Sun Mar 8 20:54:02 PDT 2015
This works for me:
- In the print composer, insert the map with size equal as the sheet, this
is: if you have an A4 sheet, the map must be same size: 297 x 210 mm.
Please tell us if it also works for you.
Carlos Cerdán
2015-03-08 22:24 GMT-05:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Hi,
> Remove all layers exept the openlayers layers. Zoom in and use the "save
> as image" option ( under project I think). Pan again and take another
> snapshot. All images will be save and georeferenced with a world file and
> you can then reload them in your project. Make sure you cite your sources.
> Nicolas Cadieux M.Sc.
> Le 2015-03-08 22:56, "lpalao [via OSGeo.org]" <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5192186&i=0>> a écrit :
> Hi QGIS users,
> I have a bit of a problem. I am using Open Layers Google Physical Layer as
> background of my other layers. When I layout my maps in Print Composer, the
> layers are well aligned. But when I export it to JPEG or PNG the output
> product is misaligned. I allow on-the-fly option when the layer from Open
> Layers were added. So, I thought this might be causing the issue. But then
> I transformed all of my layers to EPSG 3857 but still problem persist.
> Can you help me with this?
> I am using QGIS 2.6.1 Brighton installed via OSGeo.
> Thanks,
> -Leo
> Qgis-user mailing list
> <a
> href="/user/SendEmail.jtp?type=node&node=5192183&i=0">[hidden
> email]
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Export-Map-tp5192183.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
> style="font:9px serif">NAML
> View this message in context: Re: QGIS Export Map
> <http://osgeo-org.1560.x6.nabble.com/QGIS-Export-Map-tp5192183p5192186.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150308/33b40b84/attachment.html>
