[Qgis-user] Fwd: Visualize Distance matrix
Raymond Nijssen
r.nijssen at terglobo.nl
Tue Mar 10 01:08:13 PDT 2015
Hi Joris,
I dont know about that plugin, but i would write a little script for
that like this:
# get active (point) layer as input
inputlayer = iface.activeLayer()
# create new memory layer for output
outputlayer = QgsVectorLayer("Linestring", "distance_lines", "memory")
outputprovider = outputlayer.dataProvider()
# loop all points
iter = inputlayer.getFeatures()
for feature in iter:
p1 = feature.geometry().asPoint()
iter2 = layer.getFeatures()
for feature2 in iter2:
p2 = feature2.geometry().asPoint()
if not p1 == p2:
# create new line
l = QgsGeometry.fromPolyline([p1,p2])
feat = QgsFeature()
feat.setGeometry(l)
outputprovider.addFeatures([feat])
outputlayer.commitChanges()
outputlayer.updateExtents()
# add to map
QgsMapLayerRegistry.instance().addMapLayer(outputlayer)
Good luck,
Raymond
On 09-03-15 18:18, Joris Hintjens wrote:
> Thanks Raymond, but what I need is the distance from every point in a layer to every other point. That is what “distance matrix” gives me.
> Then, I want to plot every distance line (as a seperate layer?) on the map.
> Joris
>> Begin doorgestuurd bericht:
>> Datum: 9 maart 2015 15:53:56 CET
>> Van: Raymond Nijssen <r.nijssen at terglobo.nl>
>> Aan: qgis-user at lists.osgeo.org
>> Onderwerp: Antw.: [Qgis-user] Visualize Distance matrix
>> Hi Joris,
>> Not sure if I understand your question, but if you want to do a distance calculation for all points in a point layer to a certain location you can use the field calculator in the attribute table window.
>> The expression should be:
>> distance($geometry ,geomFromWKT( 'POINT(0 0)' ))
>> to calculate all distances to coordinate 0,0.
>> Hope this helps you.
>> Raymond
>> On 09-03-15 15:13, Joris Hintjens wrote:
>>> I feel stupid: I am stuck with what seems a basic operation..
>>> I have a points layer, of which I want to visualize the distance matrix.
>>> I can create the martini CSV.
>>> I cannot create a distance hub layer with the MMQGIS plugin with From and To point from within the same layer.
>>> Any help on how I ca get this result on my map?
>>> PoinA——————>PointB
>>> xxx Meter
>>> and this for the entire matrix
>>> thanks
>>> Joris
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Terglobo
>> Ampèrestraat 110
>> 5223 CT 's-Hertogenbosch
>> 06-25314983
Terglobo
Ampèrestraat 110
06-25314983
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150310/1ccfe737/attachment.png>
