[Qgis-user] Fwd: Visualize Distance matrix
Joris Hintjens
jorishin at gmail.com
Mon Mar 9 10:18:18 PDT 2015
Thanks Raymond, but what I need is the distance from every point in a layer to every other point. That is what “distance matrix” gives me.
Then, I want to plot every distance line (as a seperate layer?) on the map.
Joris
> Begin doorgestuurd bericht:
> Datum: 9 maart 2015 15:53:56 CET
> Van: Raymond Nijssen <r.nijssen at terglobo.nl>
> Aan: qgis-user at lists.osgeo.org
> Onderwerp: Antw.: [Qgis-user] Visualize Distance matrix
> Hi Joris,
> Not sure if I understand your question, but if you want to do a distance calculation for all points in a point layer to a certain location you can use the field calculator in the attribute table window.
> The expression should be:
> distance($geometry ,geomFromWKT( 'POINT(0 0)' ))
> to calculate all distances to coordinate 0,0.
> Hope this helps you.
> Raymond
> On 09-03-15 15:13, Joris Hintjens wrote:
>> I feel stupid: I am stuck with what seems a basic operation..
>> I have a points layer, of which I want to visualize the distance matrix.
>> I can create the martini CSV.
>> I cannot create a distance hub layer with the MMQGIS plugin with From and To point from within the same layer.
>> Any help on how I ca get this result on my map?
>> PoinA——————>PointB
>> xxx Meter
>> and this for the entire matrix
>> thanks
>> Joris
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Terglobo
> Ampèrestraat 110
> 5223 CT 's-Hertogenbosch
> 06-25314983
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150309/f535f9f7/attachment.html>
