[Qgis-user] GRASS dependency problem on OS X
Howard Frederick simbamangu at gmail.com
Tue Mar 10 21:19:05 PDT 2015
The permissions are correct - and don't forget the other part of this
mystery, that if I use QGIS with a different user, GRASS works just fine!
This implies there's something wrong with settings or prefs for my user.
I've deleted/reinstalled QGIS, removed ~/.qgis2, removed the preferences
.plist - all I can think is that there must be some other configuration
file I'm missing?
On 11 March 2015 at 01:13, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> One things that sometimes trips GRASS - executable permissions.  The
> installer is supposed to make sure GRASS is executable, because there were
> problems with that in the past.  Easy brute force method - delete QGIS and
> reinstall.
> But it would be good to know if that is still a problem for some odd
> reason.  You can check from a terminal with:
> ls -l /Applications/QGIS.app/Contents/MacOS/grass/grass.sh
> You'll see a line starting with a bunch of letters and hyphens, it should
> look like:
> -rwxr-xr-x
> If one "x" is missing, especially the last one, this could cause problems
> for one user but not another.
> On Mar 10, 2015, at 2:38 PM, Howard Frederick <simbamangu at gmail.com>
> wrote:
> > Processing algorithms for other providers work - tested R and SAGA at
> least.
> > The dependency error is thrown the moment I try to open any GRASS tool,
> and the tool dialog never appears - so there is no opportunity to even try
> to run any GRASS algorithm!
> > Error dialog:
> > Missing dependency. This algorithm cannot be run :-(
> > This algorithm requires GRASS to be run. Unfortunately, it seems that
> GRASS is not installed in your system, or it is not correctly configured to
> be used from QGIS
> > Click here to know more about how to install and configure GRASS to be
> used with QGIS
> > On 10 March 2015 at 17:17, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > I mean the Processing log for the algorithm.  Turn on that Processing
> option for keeping algorithm windows open, then you should hopefully see
> the details of the error in the algorithm window.  You might not since I'm
> not sure the dependency check shows up there.
> > Do Processing algorithms from other providers run?
> > One thing I found while checking SAGA is that I needed to delete the
> path for its configuration so it could automatically find the internal path
> again (even though the stored path was correct).  Though you get the same
> effect by trashing ~/.qgis2.
> > On Mar 10, 2015, at 8:56 AM, Howard Frederick <simbamangu at gmail.com>
> wrote:
> > > It allows GRASS to be activated in the Processing options, but gives
> the dependency error if I actually try to run any of the tools.
> > > The OS X console logs this when this failure happens:
> > > 10/03/15 16:42:05.779 QGIS[3835]: modalSession has been exited
> prematurely - check for a reentrant call to endModalSession:
> > > On 10 March 2015 at 16:25, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > > Does it allow you to turn on GRASS in Processing?  If so, you can see
> what the actual error is in the algorithm output when you try to run one if
> you turn on the Processing option to leave windows open when done.
> > > On Mar 9, 2015, at 11:47 PM, Howard Frederick <simbamangu at gmail.com>
> wrote:
> > > > Frustrating and inconsistent problem with GRASS dependency in QGIS
> 2.8 (and 2.6 before upgrading).
> > > > I get the usual "unmet dependency" error when trying to run any
> GRASS tool - but the Options link correctly to the location of the grass
> folder inside QGIS.app.
> > > > I have done a clean install, removing the preferences
> (org.qgis.QGIS2.plist), the .qgis2 folder and anything else I could find,
> but the problem persists.
> > > > The puzzle: on the same machine, if I create a new user and log in,
> GRASS tools run just fine in QGIS, with no modifications of the Processing
> configuration! Seems there is some configuration file that is messing with
> things - or possibly a path setting?
> > > > Any suggestions as to what I could look for?
> > > > _______________________________________________
> > > > Qgis-user mailing list
> > > > Qgis-user at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > > http://www.kyngchaos.com/
> > > "This is a question about the past, is it? ... How can I tell that the
> past isn't a fiction designed to account for the discrepancy between my
> immediate physical sensations and my state of mind?"
> > > - The Ruler of the Universe
> > "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is over.
> That is my duty."
> > "Don't you even hate 'em?"
> > "What good would it do if I did? If all the many millions of people of
> the allied nations devoted an entire year exclusively to hating the ____ it
> wouldn't kill one ___ nor shorten the war one day."
> > <Ha, ha> "And it might give 'em all stomach ulcers."
> > - Tarzan, on war
> [Trillian]  What are you supposed to do WITH a maniacally depressed robot?
> [Marvin]  You think you have problems?  What are you supposed to do if you
> ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000
> times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150311/ff183c14/attachment.html>
