[Qgis-user] Customised attributes form
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Mar 13 04:06:05 PDT 2015
On 03/13/2015 11:53 AM, emmexx wrote:
> Il 03/13/2015 11:36 AM, Matthias Kuhn scrisse:
>> Once you have registered your custom widget it will appear in the list
>> of available widgets in "Layer Properties" > Fields.
>> QGIS will then be able to connect it to a particular (QTreeWidget)
>> widget on a .ui form by the field name and the object name of the widget
>> on the form.
> If I understand correctly, once I have registered the custom widget,
> the connection between qgis and the .ui file must be established by
> setting the custom widget for each field I want to be customised (in
> qgis fields page). Am I right?
Yes
> I thought that once the "Attribute editor layout" was set to "Provide
> ui-file", the settings in the Fields page of qgis would cease to be
> loaded.
No
> But is there no interference between the .ui file and the field settings?
> I mean, I could associate a field in Qt interface to a combo and set
> it to a Date/Time in Qgis. Isn't that a problem? Is there a priority
> rule?
There can be interferences. It's up to you to ensure you choose
compatible settings/widgets.
Some of the edit widgets are able to deal with different widgets
(defined in the .ui file).
Matthias
