[Qgis-user] SQL to update table
Chuck Young wylie1066 at gmail.com
Sat Mar 14 14:57:19 PDT 2015
I am trying to eliminate the text "NULL" from a table.  I have imported a
set of Tiger road data and in some of the columns that I need to display
the data itr has "NULL" in the field.  If it is Null I would really like
that NOT to show up in the labeling on the map.
I have tried some standard SQL update queries but they didn't work.
I tried the following from the QSpatialite form that appears from within
QGIS.
Example:
update "mc-roadsegs" Set "RFROMHN" = "" Where "RFROMHN" = "NULL";
I also tried to construct a query from within the query builf=der at the
top of the Attribute table in Edit mode.
I really need to remove these unwanted valued.  It has been a while since I
used SQL on a routine basis so I am a bit rusty.
Any help will be much appreciated!
Thanks
Chuck
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150314/d1f0840d/attachment.html>
