[Qgis-user] SQL to update table
    Bo Victor Thomsen
    bo.victor.thomsen at gmail.com
    Sat Mar 14 15:39:49 PDT 2015
You might try:
update "mc-roadsegs" Set "RFROMHN" = "" Where "RFROMHN" IS NULL;
NULL signify the absence of a value in a field; it not a specific value;
therefore you can't use the "=" operator (as in "RFROMHN" = "NULL")
Regards
Bo Victor Thomsen
AestasGIS
Denmark
Den 14-03-2015 kl. 22:57 skrev Chuck Young:
> I am trying to eliminate the text "NULL" from a table.  I have
> imported a set of Tiger road data and in some of the columns that I
> need to display the data itr has "NULL" in the field.  If it is Null I
> would really like that NOT to show up in the labeling on the map.
> I have tried some standard SQL update queries but they didn't work.
> I tried the following from the QSpatialite form that appears from
> within QGIS.
> Example:
> update "mc-roadsegs" Set "RFROMHN" = "" Where "RFROMHN" = "NULL";
> I also tried to construct a query from within the query builf=der at
> the top of the Attribute table in Edit mode.
> I really need to remove these unwanted valued.  It has been a while
> since I used SQL on a routine basis so I am a bit rusty.
> Any help will be much appreciated!
> Thanks
> Chuck
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150314/ad36364d/attachment.html>
