[Qgis-user] DB Manager in QGIS 2.8
Alexandre Neto senhor.neto at gmail.com
Wed Mar 18 15:26:34 PDT 2015
Can you please show your sql query?
Notice that if your query result in different geometries, qgis won't be
able to choose a geometry type for the layer. I advice you to Check your
results with St_GeometryType().
Best regards,
Alexandre Neto
Em 18/03/2015 18:52, "David Fawcett" <david.fawcett at gmail.com> escreveu:
> I am running QGIS 2.8.1 on OSX 10.9.5 using William's binaries.
> The DB Manager plugin is at 0.1.20.
> I can load layers into PostGIS using the DB Manager plugin, and I can use
> the SQL window to execute a spatial query intersecting two tables.  But,
> when I check the box to load the query result as a layer, fill out the
> controls, and hit Load Now!, the layer isn't added.
> I get the little black and white 'thinking beachball', but nothing else
> happens.
> Can anyone else confirm this?  If so, I can file an issue.
> David.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150318/218315ad/attachment.html>
