[Qgis-user] Format GETFEATUREINFO request from QGISwebserver
Frank Sokolic sokolic at worldonline.co.za
Fri Mar 20 02:52:54 PDT 2015
Hi Carles,
Have you tried experimenting with the map tip display tip in QGIS? In
QGIS go to the layer properties, select "Display" and then enable
"HTML". You can then add html code to display the attribute values which
should affect the format of your GetFeatureInfo request.
Frank.
On 20/03/2015 11:26, Carles Vico Blanco wrote:
>  > > Hi, I'm new in Qgis-user List.
>  > > I wonder if it is possible to customize the html response to the
> request "GetFeatureInfo" held by QGIS Web Server in the same way as is
> done in GeoServer, MapServer or ArcGIS server with a template, css ...
>  > > For now, the result of my GETFEATUREINFO request takes certain html
> styles if displayed in the QGIS Web Client, but not shown in styles if
> displayed in another mapviewer. To do so it, I need to act on the html
> file styles but I have not found. I dont know if it is possible in QGIS
> Server?
>  > > Thank you very much!!!
>  > > Carles Vico
> Qgis-user mailing list
