[Qgis-user] Fwd: Format GETFEATUREINFO request from QGISwebserver
Carles Vico Blanco carles.vico at geografos.org
Fri Mar 20 04:23:04 PDT 2015
Hi Frank
 I've seen that but firstly I'm not sure that this option takes effect in
the Getfeatureinfo response (are you sure of this?) and then, I don't tried
it because I think in this way, you need to add an html code everytime for
each layer  (I'have a lot of layers in my projects) and I prefer to apply a
way where I can setup the getfeatureinfo response format from a single file.
Thanks for your reply!
2015-03-20 10:52 GMT+01:00 Frank Sokolic <sokolic at worldonline.co.za>:
> Hi Carles,
> Have you tried experimenting with the map tip display tip in QGIS? In QGIS
> go to the layer properties, select "Display" and then enable "HTML". You
> can then add html code to display the attribute values which should affect
> the format of your GetFeatureInfo request.
> Frank.
> On 20/03/2015 11:26, Carles Vico Blanco wrote:
>>  > > Hi, I'm new in Qgis-user List.
>>  > > I wonder if it is possible to customize the html response to the
>> request "GetFeatureInfo" held by QGIS Web Server in the same way as is
>> done in GeoServer, MapServer or ArcGIS server with a template, css ...
>>  > > For now, the result of my GETFEATUREINFO request takes certain html
>> styles if displayed in the QGIS Web Client, but not shown in styles if
>> displayed in another mapviewer. To do so it, I need to act on the html
>> file styles but I have not found. I dont know if it is possible in QGIS
>> Server?
>>  > > Thank you very much!!!
>>  > > Carles Vico
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150320/e95f3d10/attachment.html>
