[Qgis-user] Problem Displaying KML Files in QGIS 2.10.1 64-bit	Windows 7
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Mon Nov  9 14:14:36 PST 2015
Your kml files appear to be GoogleEarth web page links more then actual
vector layer files.  I can open them in Google Earth (pro that is free
now).   The bounding box is 3D and does not appear to be usable in Qgis.
The points are.
When you click on the points in GoogleEarth, they send you to this page:
https://www.sciencebase.gov/catalog/item/55db4088e4b0518e35470837
Hope this helps!
Nicolas
Le 2015-11-08 00:51, tmorse [via OSGeo.org] a écrit :
> I'm trying to display two KML layers of U.S. Pacific coast littoral
> cells, one line and one polygon
> (https://www.sciencebase.gov/catalog/item/55ce7ca2e4b01487cbfc711a),
> in QGIS 2.10.1 without success.
> I am able to display the line file in Google Earth. I think I once
> succeeded in opening the polygon file in Google Earth, but
> subsequently have been unable to, so I may be mistaken. I can't tell
> whether the polygon file just takes inordinately long to open, or
> whether there is something wrong with it.
> I can add both files to QGIS as vector layers, but no lines or
> polygons are visible. When I open the properties dialogues for each,
> the style and labels tabs are blank. If I try to save the layer as a
> shapefile, I get the error:
>     Export to vector file failed.
>     Error: creation of layer failed (OGR error:Geometry type of `3D
>     Geometry Collection' not supported in shapefiles.
>     Type can be overridden with a layer creation option
>     of
>     SHPT=POINT/ARC/POLYGON/MULTIPOINT/POINTZ/ARCZ/POLYGONZ/MULTIPOINTZ.)
> If I try to save the layer as a shape file using that layer creation
> option, it fails with the error:
>     Error: creation of layer failed (OGR error:Unknown SHPT value of
>     `POINT/ARC/POLYGON/MULTIPOINT/POINTZ/ARCZ/POLYGONZ/MULTIPOINTZ'
>     passed to Shapefile layer creation. Creation aborted.)
> Can anyone suggest how I can open these files in QGIS? I have
> successfully opened other KML files as layers in QGIS, so I think the
> problem is with these specific files, not QGIS's ability to handle KML
> files.
> Thank you,
> Terry Morse
> [hidden email] </user/SendEmail.jtp?type=node&node=5235055&i=0>
> Qgis-user mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5235055&i=1>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Problem-Displaying-KML-Files-in-QGIS-2-10-1-64-bit-Windows-7-tp5235055.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-Displaying-KML-Files-in-QGIS-2-10-1-64-bit-Windows-7-tp5235055p5235389.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151109/63441a2c/attachment.html>
