[Qgis-user] Problems with Plugins
    Luigi Pirelli
    luipir at gmail.com
    Mon Nov 16 01:44:11 PST 2015
I filed the issue... Alex Bruy will be in charge to update the plugin with
the correct metadata.txt
https://hub.qgis.org/issues/13837
in this thread I'll notify when the update will be available... in the
meantime please remvoe .qgis/python/plugins/processing if your qgis version
is less that 2.12
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 16 November 2015 at 10:23, Luigi Pirelli <luipir at gmail.com> wrote:
> 2.12 works on qgis master... probably victor forgot to set minimal
> compatible version in processing plugin metadata.txt
> Luigi Pirelli
> * Mastering QGIS:
> On 16 November 2015 at 10:20, Luigi Pirelli <luipir at gmail.com> wrote:
>> hi Marta
>> temporarly do this
>> remove <your home path>/.qgis2/python/plugins/processing directory
>> in this way you'll use the processing distributed with your qgis
>> installed version (that I suppose is a stable version)
>> every time will be asked you to upgrade Processing (in LTR the
>> distributed version is 2.6 and ask to upgrade to 2.12)... don't upgrade!
>> until the problem is resolved.
>> regards
>> Luigi Pirelli
>> * Mastering QGIS:
>> On 16 November 2015 at 03:19, Marta Modolo <marta.modolo at gmail.com>
>> wrote:
>>> Hi to everybody,
>>> I contact you because i've got some problem with these plugins: Profile
>>> from points, Buffer by Percentage, clip multiple layers, dissolve with
>>> stats, multi-distante buffer and Processing. When I open QGis the program
>>> say me that: *Questo plugin รจ corrotto*
>>> cannot import name show_message_log
>>> Can you help me please?
>>> Thank you in advance
>>> Marta
>>> Marta Modolo
>>> PhD candidate in Cuaternario y Prehistoria
>>> Universitat Rovira i Virgili
>>> Avinguda Catalunya, 35
>>> 43002 Tarragona (Spain)
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151116/096b8448/attachment.html>
