[Qgis-user] Editing only the selected feature
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Nov 16 02:33:20 PST 2015
Hi Christian,
marking features as editing finished can IMHO only be realized in the
feature's attributes. Insert a boolean field "editing_finished" in the
layer's attributes. With this I see two workarounds:
1) if you are on a database layer: Have a trigger that prevents the
geometry from being changed if editing_finished = true
2) Should work on all data sources: Load the layer twice: Once with
filter editing_finished = false (this is the layer you work in) and once
with editing_finished = true. If you have finished editing a feature set
its editing_finished attribute to true and save edits. The feature will
be "moved" from the edit layer to the editing_finished layer
Bernhard
Am 16.11.2015 um 11:06 schrieb Christian Röttger:
> Hi,
> at the moment i try to convince my boss to change to qgis for a greater
> digitizing project.
> One question is, if it is possible to edit only one (maybe more)
> selected feature?
> As an example: I edit a polygon. When his is complete it shouldn't be
> touched anymore. Then i edit the neighbour polygon, maybe with "advanced
> editig" -> "Reshape Features" and digitize (unintentionally) over a
> corner or boarder of the first polygon. So both features are changed.
> Summarized, is it possible to edit only one selected feature or does
> anyone know a workaround?
> Thanks and cheers
> Christian
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
__________ Information from ESET Mail Security, version of virus signature database 12573 (20151116) __________
The message was checked by ESET Mail Security.
http://www.eset.com
