[Qgis-user] Editing only the selected feature
Christian Röttger
chris.roettger at web.de
Mon Nov 16 03:11:13 PST 2015
Hi Bernhard,
thanks for your answer. That are the solutions we also thought about.
Further we want to implement an own plugin where we can handle this in a
better way.
It was possible that there was some build in function already, which i
didn't find. Is there someone here, who already developed a plugin which
only edits selected features? Maybe this is possible with direct api acces
or is always the complete layer editable?
cheers
Christian
2015-11-16 11:33 GMT+01:00 Bernhard Ströbl <bernhard.stroebl at jena.de>:
> Hi Christian,
> marking features as editing finished can IMHO only be realized in the
> feature's attributes. Insert a boolean field "editing_finished" in the
> layer's attributes. With this I see two workarounds:
> 1) if you are on a database layer: Have a trigger that prevents the
> geometry from being changed if editing_finished = true
> 2) Should work on all data sources: Load the layer twice: Once with filter
> editing_finished = false (this is the layer you work in) and once with
> editing_finished = true. If you have finished editing a feature set its
> editing_finished attribute to true and save edits. The feature will be
> "moved" from the edit layer to the editing_finished layer
> Bernhard
> Am 16.11.2015 um 11:06 schrieb Christian Röttger:
>> Hi,
>> at the moment i try to convince my boss to change to qgis for a greater
>> digitizing project.
>> One question is, if it is possible to edit only one (maybe more)
>> selected feature?
>> As an example: I edit a polygon. When his is complete it shouldn't be
>> touched anymore. Then i edit the neighbour polygon, maybe with "advanced
>> editig" -> "Reshape Features" and digitize (unintentionally) over a
>> corner or boarder of the first polygon. So both features are changed.
>> Summarized, is it possible to edit only one selected feature or does
>> anyone know a workaround?
>> Thanks and cheers
>> Christian
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> __________ Information from ESET Mail Security, version of virus signature
> database 12573 (20151116) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151116/20c8d809/attachment.html>
