[Qgis-user] QGIS Segmentation fault
Matthias Kuhn
matthias at opengis.ch
Wed Nov 18 12:15:14 PST 2015
Yes, compile with CMAKE_BUILD_TYPE=Debug
then run it in gdb, I normally do from the build directory
cd build
gdb ./output/bin/qgis
run
... wait for the crash
bt
... copy paste
Cheers,
Matthias
On 11/18/2015 09:08 PM, Blumentrath, Stefan wrote:
> Hi,
> How do I backtrace?
> Do I have to build with debug functionality first?
> Cheers
> Stefan
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Matthias Kuhn
> *Sent:* 18. november 2015 21:06
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] QGIS Segmentation fault
> Would any of you be able to produce a backtrace from this crash, paste
> it into the issue linked below and send a short reminder here?
> Thanks
> Matthias
> On 11/18/2015 06:57 PM, Blumentrath, Stefan wrote:
> Same here. Took the liberty to open a ticket:
> https://hub.qgis.org/issues/13849
> Yet, older versions of QGIS (2.10) crash equally…
> Cheers
> Stefan
> Behalf Of *samuelmesa at gmail.com <mailto:samuelmesa at gmail.com>
> *Sent:* 31. oktober 2015 18:36
> *To:* Paulo van Breugel <p.vanbreugel at gmail.com>
> <mailto:p.vanbreugel at gmail.com>
> *Cc:* QGIS user email list <qgis-user at lists.osgeo.org>
> <mailto:qgis-user at lists.osgeo.org>
> I confirm the same problem for QGIS 2.12 in Arch Linux:
> Warning: QCss::Parser - Failed to load file "/style.qss"
> Then closes unexpectedly.
> regards,
> Samuel Mesa.
> 2015-09-21 5:45 GMT-05:00 Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>>:
> Hi, Just compiled the latest QGIS master (on Linux Ubuntu
> 14.04). Now, when opening QGIS, it opens, after which it
> immediately crashes, with the following sparse message:
> Warning: loading of qgis translation failed
> [/usr/local/qgis/share/qgis/i18n//qgis_en_US]
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
> Warning: void DBusMenuExporterPrivate::addAction(QAction*,
> int): Already tracking action "&Toolbox" under id 237
> ERROR 4: `/initrd.img' not recognised as a supported file format.
> Segmentation fault (core dumped)
> Any idea?
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> / v \
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
Matthias Kuhn
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151118/13b00e65/attachment.html>
