[Qgis-user] QGIS Segmentation fault
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Nov 18 15:26:25 PST 2015
Hi again,
Thanks for the instruction. Here is my backtrace:
pdb ./output/bin/qgis
File "/usr/lib/python2.7/pdb.py", line 1314, in main
pdb._runscript(mainpyfile)
File "/usr/lib/python2.7/pdb.py", line 1233, in _runscript
self.run(statement)
File "/usr/lib/python2.7/bdb.py", line 400, in run
exec cmd in globals, locals
File "<string>", line 1, in <module>
File "./output/bin/qgis", line 1
ELF
SyntaxError: invalid syntax
Uncaught exception. Entering post mortem debugging
Running 'cont' or 'step' will restart the program
Bt
/usr/lib/python2.7/pdb.py(1314)main()
-> pdb._runscript(mainpyfile)
/usr/lib/python2.7/pdb.py(1233)_runscript()
-> self.run(statement)
/usr/lib/python2.7/bdb.py(400)run()
-> exec cmd in globals, locals
> <string>(1)<module>()
Hope anyone can get something out of it.
Cheers
Stefan
From: Matthias Kuhn [mailto:matthias at opengis.ch]
Sent: 18. november 2015 21:15
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS Segmentation fault
Yes, compile with CMAKE_BUILD_TYPE=Debug
then run it in gdb, I normally do from the build directory
cd build
gdb ./output/bin/qgis
run
... wait for the crash
bt
... copy paste
Cheers,
Matthias
On 11/18/2015 09:08 PM, Blumentrath, Stefan wrote:
How do I backtrace?
Do I have to build with debug functionality first?
Cheers
Stefan
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthias Kuhn
Sent: 18. november 2015 21:06
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Would any of you be able to produce a backtrace from this crash, paste it into the issue linked below and send a short reminder here?
Thanks
Matthias
On 11/18/2015 06:57 PM, Blumentrath, Stefan wrote:
Same here. Took the liberty to open a ticket:
https://hub.qgis.org/issues/13849
Yet, older versions of QGIS (2.10) crash equally...
Cheers
Stefan
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of samuelmesa at gmail.com<mailto:samuelmesa at gmail.com>
Sent: 31. oktober 2015 18:36
To: Paulo van Breugel <p.vanbreugel at gmail.com><mailto:p.vanbreugel at gmail.com>
Cc: QGIS user email list <qgis-user at lists.osgeo.org><mailto:qgis-user at lists.osgeo.org>
I confirm the same problem for QGIS 2.12 in Arch Linux:
Warning: QCss::Parser - Failed to load file "/style.qss"
Then closes unexpectedly.
regards,
Samuel Mesa.
2015-09-21 5:45 GMT-05:00 Paulo van Breugel <p.vanbreugel at gmail.com<mailto:p.vanbreugel at gmail.com>>:
Hi, Just compiled the latest QGIS master (on Linux Ubuntu 14.04). Now, when opening QGIS, it opens, after which it immediately crashes, with the following sparse message:
Warning: loading of qgis translation failed [/usr/local/qgis/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed [/usr/share/qt4/translations/qt_en_US]
Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "&Toolbox" under id 237
ERROR 4: `/initrd.img' not recognised as a supported file format.
Segmentation fault (core dumped)
Any idea?
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
/ v \
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial * (Q)GIS * PostGIS * Open Source
Matthias Kuhn
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151118/0ac91259/attachment.html>
