[Qgis-user] QGIS 2.8.1 launch aborts with core dumped
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Sat Nov 28 08:01:33 PST 2015
I am facing a similar issue with the other QGIS Versions on the same OS.
I suspect it is a kernel issue. Did you install latest Ubuntu kernel? That hopefully fixes the issue (I am testing at the moment...).
Cheers
Stefan
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> im Auftrag von Alexandre Neto <senhor.neto at gmail.com>
Gesendet: Samstag, 28. November 2015 02:22
An: GFZ Hydrologie; qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] QGIS 2.8.1 launch aborts with core dumped
Try erase or rename your .qgis2 folder.
Alexandre Neto
A 15h21 Sex, 27 de Nov de 2015, GFZ Hydrologie <sec54gfz at gmail.com<mailto:sec54gfz at gmail.com>> escreveu:
Dear list,
on kubuntu 14.04 LTS (running in Virtual Box on Windows 7) QGIS 2.8.1 launch aborts with core dumped.
So far I
purged qgis, removed all qgis plugins
re installed using repository
http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/
but without any success
on another machine with similar OS and QGIS there are no such problems.
any ideas?
cheers
kai
Warning: loading of qgis translation failed [/usr/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed [/usr/share/qt4/translations/qt_en_US]
Warning: Bus::open: Can not get ibus-daemon's address.
IBusInputContext::createInputContext: no connection to ibus-daemon
Warning: QGraphicsScene::addItem: item has already been added to this scene
Fatal: ASSERT failure in QList<T>::operator[]: "index out of range", file /usr/include/qt4/QtCore/qlist.h, line 477
Stacktrace (piped through c++filt):
/usr/bin/qgis.bin[0x509ba0]
/usr/bin/qgis.bin(myMessageOutput(QtMsgType, char const*)+0x38)[0x509ca8]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(qt_message_output(QtMsgType, char const*)+0x21)[0x7f6e8d568bb1]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x70ff9)[0x7f6e8d568ff9]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(qFatal(char const*, ...)+0x94)[0x7f6e8d569804]
/usr/lib/libqgis_gui.so.2.8.1(QgsScaleComboBox::updateScales(QStringList const&)+0x127)[0x7f6e8e1ecae7]
/usr/lib/libqgis_gui.so.2.8.1(QgsScaleComboBox::QgsScaleComboBox(QWidget*)+0x54)[0x7f6e8e1ed054]
/usr/bin/qgis.bin(QgisApp::createStatusBar()+0xa30)[0x519140]
/usr/bin/qgis.bin(QgisApp::QgisApp(QSplashScreen*, bool, QWidget*, QFlags<Qt::WindowType>)+0xbb9)[0x54e9b9]
/usr/bin/qgis.bin(main+0x132b)[0x50421b]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7f6e8a4c5ec5]
/usr/bin/qgis.bin[0x5095e8]
Aborted (core dumped)
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151128/81619622/attachment.html>
