[Qgis-user] Error when "save as" the dataset
Andre Joost
andre+joost at nurfuerspam.de
Thu Oct 1 08:33:16 PDT 2015
Am 29.09.2015 um 17:33 schrieb Andrea Peri:
> Exportation in the vector file faildes
> Error: errors in the write:
> Geometry of the elements not imported (OGR error).
> I notice also that if I select a few elements and repeat the save-as
> using ony selected elements.
> All go ok.
> Instead if I select ALL the elements of the dataset and try the export with
> save-a (using selection)
> have again the ogr error.
> Perhaps a memory error ?
Maybe a geometry error. Have you tested it with the Geometry checker?
Or mixed geometries, which are not allowed for shapefiles? You could try
an export to spatialite in this case.
HTH,
André Joost
