[Qgis-user] Error when "save as" the dataset
Giuseppe Sucameli
brush.tyler at gmail.com
Thu Oct 1 11:01:06 PDT 2015
it has been fixed [1].
Best regards.
Giuseppe
[1] http://hub.qgis.org/issues/13451
Sent from mobile. Sorry for being short.
Giuseppe Sucameli
Il 01/ott/2015 18:35, "Andre Joost" <andre+joost at nurfuerspam.de> ha scritto:
> Am 29.09.2015 um 17:33 schrieb Andrea Peri:
>> Exportation in the vector file faildes
>> Error: errors in the write:
>> Geometry of the elements not imported (OGR error).
>> I notice also that if I select a few elements and repeat the save-as
>> using ony selected elements.
>> All go ok.
>> Instead if I select ALL the elements of the dataset and try the export
>> with
>> save-a (using selection)
>> have again the ogr error.
>> Perhaps a memory error ?
> Maybe a geometry error. Have you tested it with the Geometry checker?
> Or mixed geometries, which are not allowed for shapefiles? You could try
> an export to spatialite in this case.
> HTH,
> André Joost
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151001/23660d25/attachment.html>
