[Qgis-user] QGIS - value relation widget
Luca Lanteri
lklanteri at gmail.com
Fri Oct 2 05:17:32 PDT 2015
I continue my work and I discover another problem.I have a 3 level nested
form (granparent-parent and child).
If I don't use global variables when I select a record in child to parent
and then one in parent, QGIS raise an error:
File
"E:/lavori/Progetti_PIE/Convenzione_SISMICA/NomeComune_RP_v2.1.3_alpha1\indaginipun.py",
line 42, in
LedQtop.textChanged.connect(lambda: validaQuota(LedQtop))
NameError: free variable 'LedQtop' referenced before assignment in
enclosing scope
to avoid this error I have to declare some variable in my parent form but
then I have a minidump error when insert new records.
I'm in a "cul de sac". To hard for my weak python knowledge
thanks for all
Luca
2015-10-02 10:57 GMT+02:00 Luca Lanteri <lklanteri at gmail.com>:
> Great Matthias,
> I remove all global variables and now it work fine !
> It remain just one problem, I add some code [0] connected with a button to
> insert a filename in a field.
> If use the button from single form all works fine but when I use it in
> from the parent-child form the code start lot of times (it seems one time
> for every record in the table).
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151002/986aca9d/attachment.html>
