[Qgis-user] Editable GeoCSV
Peter Borbely pborbely at fairfaxmedia.com.au
Sun Oct 4 19:20:55 PDT 2015
Thanks for your help Nathan
I'll have to dig into a bit of how to interact with QGIS via the python
console a bit (and brush off my barely anything python memories)
I tried
QSettings().setValue('locale/userLocale', 'en_AU')
  File "<input>", line 1, in <module>
NameError: name 'QSettings' is not defined
and
QgisInterface(PyQt4.QtCore.QSettings().setValue('locale/userLocale',
'en_AU'))
NameError: name 'QgisInterface' is not defined
with errors.
I gotta get a project out in 3 hours, so I will have to come back to this.
I worked around the data issue (outside of qgis), so this is now more just
to gain more skills.
Peter Borbély
<myemail at fairfaxmedia.com.au>
Interactivista
Fairfax Media
1 Darling Island Road, Pyrmont 2009
+61 2 8596 4745
pborbely at fairfaxmedia.com.au | @datafunk <http://twitter.com/datafunk>
On 5 October 2015 at 13:02, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> That is the error.
> The plugin has this line:
>         locale = QSettings().value('locale/userLocale')[0:2]
> which is crashing because it gets NULL and then tries to slice it and
> fails.
> Try this:
> I'm not sure why it is returning NULL but that should fix it.
> Regards,
> On Mon, Oct 5, 2015 at 9:35 AM, Peter Borbely <
> pborbely at fairfaxmedia.com.au> wrote:
>> mine returns NULL - I'll poke around and set it and report back
>> Peter Borbély
>> Interactivista
>> Fairfax Media
>> +61 2 8596 4745
>> On 5 October 2015 at 10:32, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>> Try this (just seeing if this where the error in the plugin is)
>>> - Open the Python console and paste the following
>>> from PyQt4.QtCore import *; QSettings().value('locale/userLocale')
>>> Does that return anything?  Mine returns u'en_AU'
>>> On Mon, Oct 5, 2015 at 9:23 AM, Peter Borbely <
>>>> I looked through the plugin logs, but couldn't find any reference to *QPyNullVariant
>>>> *or * '__getitem__'*
>>>> happy to post my logs if you think they help, maybe I should look for
>>>> something else?
>>>> Peter Borbély
>>>> Interactivista
>>>> Fairfax Media
>>>> +61 2 8596 4745
>>>> On 5 October 2015 at 10:09, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>> Hey Peter,
>>>>> Seems to work for me here.  Does it list anymore information at all?
>>>>> It should hopefully have what line the error is on.
>>>>> Regards,
>>>>> On Mon, Oct 5, 2015 at 8:48 AM, Peter Borbely <
>>>>>> Hi there
>>>>>> I've tried to install the plugin *Editable GeoCSV*
>>>>>> and got the following error:
>>>>>> "the plugin is broken. Python said:
>>>>>> *'QPyNullVariant' object has no attribute '__getitem__'*
>>>>>> The prompt suggested to post this to the list here.
>>>>>> cheers
>>>>>> peter
>>>>>> Peter Borbély
>>>>>> Interactivista
>>>>>> Fairfax Media
>>>>>> +61 2 8596 4745
>>>>>> The information contained in this e-mail message and any accompanying
>>>>>> files is or may be confidential. If you are not the intended recipient, any
>>>>>> use, dissemination, reliance, forwarding, printing or copying of this
>>>>>> e-mail or any attached files is unauthorised. This e-mail is subject to
>>>>>> copyright. No part of it should be reproduced, adapted or communicated
>>>>>> without the written consent of the copyright owner. If you have received
>>>>>> this e-mail in error please advise the sender immediately by return e-mail
>>>>>> or telephone and delete all copies. Fairfax Media does not guarantee the
>>>>>> accuracy or completeness of any information contained in this e-mail or
>>>>>> attached files. Internet communications are not secure, therefore Fairfax
>>>>>> Media does not accept legal responsibility for the contents of this message
>>>>>> or attached files.
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> or attached files.
>> or attached files.
The information contained in this e-mail message and any accompanying files
is or may be confidential. If you are not the intended recipient, any use,
dissemination, reliance, forwarding, printing or copying of this e-mail or
any attached files is unauthorised. This e-mail is subject to copyright. No
part of it should be reproduced, adapted or communicated without the
written consent of the copyright owner. If you have received this e-mail in
error please advise the sender immediately by return e-mail or telephone
and delete all copies. Fairfax Media does not guarantee the accuracy or
completeness of any information contained in this e-mail or attached files.
Internet communications are not secure, therefore Fairfax Media does not
accept legal responsibility for the contents of this message or attached
files.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151005/dcbe1a96/attachment.html>
