[Qgis-user] Editable GeoCSV
Nathan Woodrow
madmanwoo at gmail.com
Sun Oct 4 19:59:57 PDT 2015
On Mon, Oct 5, 2015 at 12:20 PM, Peter Borbely <pborbely at fairfaxmedia.com.au
> wrote:
> QSettings().setValue('locale/userLocale', 'en_AU')
For some reason that setting is null when the plugin asks for it but not in
the options which I'm not sure why. This is a external plugin so the author
will need that handle that case.
Here are some workarounds for now.
Run this:
from PyQt4.QtCore import *
You need to import the module and then use the settings class.
Or you can put the attached file into .qgis2\python\plugins\editablegeocsv
folder. I have patched this file so it should work.
Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151005/f2c69438/attachment.html>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151005/f2c69438/attachment.py>
