[Qgis-user] The XML of getcapabilities should not have any ascii code over 128
Andreas Neumann
a.neumann at carto.net
Sat Oct 10 07:49:59 PDT 2015
Hi Andrea/Matthias,
XML can clearly host UTF-8 or UTF-16 - the whole character range -
depending on what you use in your text editor and specify in your XML
header.
However, there are some reserved characters, like:
* < (lesser sign)
* > (greater sign)
* " (double quotes)
* & (ampersand)
Did I miss one?
Normally, the XML parser/writer automatically takes care about properly
escaping/unescaping these characters - if not, I would consider this a
bug in QGIS. Not only would the OWS outputs be non-wellformed, but also
QGIS desktop would have a problem with non-wellformed .qgs files.
I never experienced such an issue.
Andrea: can you be more precise with the offending characters and a
small demo project?
Thanks,
Andreas
On 06.10.2015 22:36, Andrea Peri wrote:
> HI Matthias,
> I'm not able to reproduce the issue.
> My try to produce a small project.
> I'm sure why it is not reproducable.
> Perhaps beyond the original issue there was some else trouble.
> Perhaps a bad trasmission ?
> I don't know at now.
> So I can only suspect that the issue was another and when I resend the
> new project with my changes, I unconsciously resolve also the real
> issue.
> I return on this issue if it will reappear.
> Thx for all,
> Andrea.
> 2015-10-06 18:17 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
>> Hi Andrea
>> I would suggest to open an issue report with a description of the problem
>> and attach a link to an affected service or attach an affected project file.
>> In the details of the report you can outline the workaround which you are
>> currently taking (i.e. only preserve standard 7-bit ascii characters) as
>> well as a short summary of and a link to this discussion here.
>> Regards,
>> Matthias
>> On 10/04/2015 07:13 PM, Andrea Peri wrote:
>> In the xml response.
>> When it happened I go into the metadata abstracts using the qgis gui, remove
>> any character over 7bit code and after this the response became well formed.
>> Actually we use qgis-server 2.6.
>> A.
>> Il 04/ott/2015 18:31, "Matthias Kuhn" <matthias at opengis.ch> ha scritto:
>>> Hi Andrea,
>>> On 10/04/2015 05:55 PM, aperi2007 wrote:
>>> Hi Mattias,
>>> Sorry but this question is hard to understand for me .
>>> Perhaps I miss to analyze another step:
>>> If the operating system of the user is with a character set different from
>>> UTF8.
>>> And the user is editing a qgis project.
>>> The qgis project what character set is using ?
>>> AFAIK the qgis carset is set in the properties page of qgis.
>>> Where exactly do you start experiencing strange behavior?
>>> In the text box in the properties, in the project file or only in the XML
>>> response from the server?
>>> -- Matthias
>>> If this is true,
>>> How can the clipboard of the operating system to know what is the charset
>>> set in the properties page of qgis ?
>>> AFAIK the clipboard change always and only in the charset of the OS.
>>> A.
>>> Il 04/10/2015 15:30, Matthias Kuhn ha scritto:
>>> Hi Andrea,
>>> Is it really that there should only be 7bit characters or is it that the
>>> encoding is not properly set in the answer?
>>> XML fully supports utf-8 (it is even the default character encoding) and
>>> I assume that in 2015 every modern XML client should support this as well.
>>> Can you give an example server address and ideas of affected clients?
>>> I have the feeling that there's something else fishy and if there is
>>> really a need to replace characters above 127 then it should be an
>>> opt-in configuration option.
>>> Matthias
>>> On 10/04/2015 11:59 AM, Andrea Peri wrote:
>>> Hi,
>>> we experienced this user case problem.
>>> In the qgis-server getcapabilities response the information of the
>>> "Abstract" is taken from the field:
>>> layer-properties -> metadata -> Abstract.
>>> But ofet the user fill this field with some cut/paste from other
>>> documents.
>>> So doing, if fill this field with many unacceptable character.
>>> Like these:
>>> or the very hard to see "no blank space".
>>> The qgis accept all of this without any problem,
>>> but when return the repsonse from a GetCapabiities request.
>>> The response is not valid for the xml.
>>> So many standard xml clients report a not well formed xml.
>>> We don't have any good ideas to how resolve this issue.
>>> My question is if could be possible in the qgis-server site to do a
>>> xml conversion of all this character.
>>> Instead of send them directly.
>>> AFAIK all of this could be coded to be corected coded in a XML response.
>>> Any thought on this ?
>>> Thx.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
