[Qgis-user] The XML of getcapabilities should not have any ascii code over 128
Andrea Peri aperi2007 at gmail.com
Tue Oct 6 13:36:25 PDT 2015
HI Matthias,
I'm not able to reproduce the issue.
My try to produce a small project.
I'm sure why it is not reproducable.
Perhaps beyond the original issue there was some else trouble.
Perhaps a bad trasmission ?
I don't know at now.
So I can only suspect that the issue was another and when I resend the
new project with my changes, I unconsciously resolve also the real
issue.
I return on this issue if it will reappear.
Thx for all,
Andrea.
2015-10-06 18:17 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Andrea
> I would suggest to open an issue report with a description of the problem
> and attach a link to an affected service or attach an affected project file.
> In the details of the report you can outline the workaround which you are
> currently taking (i.e. only preserve standard 7-bit ascii characters) as
> well as a short summary of and a link to this discussion here.
> Regards,
> Matthias
> On 10/04/2015 07:13 PM, Andrea Peri wrote:
> In the xml response.
> When it happened I go into the metadata abstracts using the qgis gui, remove
> any character over 7bit code and after this the response became well formed.
> Actually we use qgis-server 2.6.
> A.
> Il 04/ott/2015 18:31, "Matthias Kuhn" <matthias at opengis.ch> ha scritto:
>> Hi Andrea,
>> On 10/04/2015 05:55 PM, aperi2007 wrote:
>> Hi Mattias,
>> Sorry but this question is hard to understand for me .
>> Perhaps I miss to analyze another step:
>> If the operating system of the user is with a character set different from
>> UTF8.
>> And the user is editing a qgis project.
>> The qgis project what character set is using ?
>> AFAIK the qgis carset is set in the properties page of qgis.
>> Where exactly do you start experiencing strange behavior?
>> In the text box in the properties, in the project file or only in the XML
>> response from the server?
>> -- Matthias
>> If this is true,
>> How can the clipboard of the operating system to know what is the charset
>> set in the properties page of qgis ?
>> AFAIK the clipboard change always and only in the charset of the OS.
>> A.
>> Il 04/10/2015 15:30, Matthias Kuhn ha scritto:
>> Hi Andrea,
>> Is it really that there should only be 7bit characters or is it that the
>> encoding is not properly set in the answer?
>> XML fully supports utf-8 (it is even the default character encoding) and
>> I assume that in 2015 every modern XML client should support this as well.
>> Can you give an example server address and ideas of affected clients?
>> I have the feeling that there's something else fishy and if there is
>> really a need to replace characters above 127 then it should be an
>> opt-in configuration option.
>> Matthias
>> On 10/04/2015 11:59 AM, Andrea Peri wrote:
>> Hi,
>> we experienced this user case problem.
>> In the qgis-server getcapabilities response the information of the
>> "Abstract" is taken from the field:
>> layer-properties -> metadata -> Abstract.
>> But ofet the user fill this field with some cut/paste from other
>> documents.
>> So doing, if fill this field with many unacceptable character.
>> Like these:
>> or the very hard to see "no blank space".
>> The qgis accept all of this without any problem,
>> but when return the repsonse from a GetCapabiities request.
>> The response is not valid for the xml.
>> So many standard xml clients report a not well formed xml.
>> We don't have any good ideas to how resolve this issue.
>> My question is if could be possible in the qgis-server site to do a
>> xml conversion of all this character.
>> Instead of send them directly.
>> AFAIK all of this could be coded to be corected coded in a XML response.
>> Any thought on this ?
>> Thx.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
