[Qgis-user] QML reference, symbolize synonyms alike
Richard McDonnell
richard.mcdonnell at opw.ie
Thu Oct 15 03:46:59 PDT 2015
Peter
I would advise you to use the QGIS rule based symbology to do what you
require, the filter would be something like:-
/*your attribute_column _name*/ = 'carbonate rock' OR area_code =
'carbonate'
keeping it simple!!
This should do the trick for you.
Regards,
Richard.
On 14/10/2015 17:20, Schweitzer, Peter wrote:
> Is there a QML reference document?
> What I really want to do is specify that two different category values
> will have the same symbol, like this:
> <category render="true" symbol="64" value="carbonate rock"
> label="Carbonate rock"/>
> <category render="true" symbol="64" value="carbonate" label="Carbonate rock"/>
> I want to read this as
> when the value of the attribute is EITHER "carbonate rock" OR
> "carbonate", render the feature using the symbol named "64"
> But this does not have the effect that I want, so I'm thinking
> incorrectly about how the QML file works.
> I would welcome advice on how to do what I want, or direction to the
> QML reference, or both.
> Thanks!
> Peter
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151015/7948bc1d/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151015/7948bc1d/attachment.vcf>
