[Qgis-user] WMS display issue and QGIS based standalone application
Thomas Gratier
osgeo.mailinglist at gmail.com
Sat Oct 17 09:45:30 PDT 2015
Thanks for your answer. I'm using QGIS 2.10.1-Pisa on an Ubuntu 14.04 LTS
For both scripts, you will see screenshots for non working sample
https://framapic.org/ESs6fNmIArII/uFqt0e0A and also working one
https://framapic.org/21atQvjmzdq5/4whPjPGL.
Unfortunately, except if there is a debug option to activate for standalone
debug, I don't have any output in the console when running both scripts.
Regards
Thomas Gratier
2015-10-13 23:59 GMT+02:00 Salvatore Larosa <lrssvtml at gmail.com>:
> Hi Thomas,
> On Mon, Oct 12, 2015 at 6:08 PM, Thomas Gratier
> <osgeo.mailinglist at gmail.com> wrote:
> > Hi,
> > I'm working with the Python API to create a standalone app.
> > When I reuse this sample from
> > http://kartoza.com/how-to-load-a-qgis-project-in-python/, it works
> perfectly
> > with only vector layer(s).
> > When I use a WMS with a vector layer, it fails directly.
> > I've done two samples to demonstrate the issue. You can take samples from
> https://framadrop.org/r/kkC2MVV9TH#anlncOhrg5vbo5W7D8Lfjg8ghRq7BTo9flJXvnIV+Io=
> > Run the working vector sample with:
> > python test_project_standalone_no_wms.py
> > Run the non working wms + vector sample with:
> > python test_project_standalone.py
> > I should miss something. Do you have any clue? It's a bug or a feature
> > (unwanted for my case)?
> which QGIS version are you trying with?
> Using master and LTR both scripts do not work for me.
> For the non working script are you getting any log in the python shell?
> Best Regards,
> -SL
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151017/e02a1247/attachment.html>
