[Qgis-user] WMS display issue and QGIS based standalone application
Tim Sutton
tim at qgis.org
Wed Oct 21 14:28:06 PDT 2015
Hi Thomas
> On 12 Oct 2015, at 18:08, Thomas Gratier <osgeo.mailinglist at gmail.com> wrote:
> Hi,
> I'm working with the Python API to create a standalone app.
> When I reuse this sample from http://kartoza.com/how-to-load-a-qgis-project-in-python/ <http://kartoza.com/how-to-load-a-qgis-project-in-python/>, it works perfectly with only vector layer(s).
> When I use a WMS with a vector layer, it fails directly.
> I've done two samples to demonstrate the issue. You can take samples from https://framadrop.org/r/kkC2MVV9TH#anlncOhrg5vbo5W7D8Lfjg8ghRq7BTo9flJXvnIV+Io= <https://framadrop.org/r/kkC2MVV9TH#anlncOhrg5vbo5W7D8Lfjg8ghRq7BTo9flJXvnIV+Io=>
It seems like that framadrop.org site is broken (FileConstructor is not a constructor (evaluating 'new File(a, data.name, {type: data.type})’)) so I cannot view the example. But you said above that you were trying ‘WMS with a vector layer’ so I am wondering if you have been trying to add a WMS layer as a raster layer rather than a vector layer? If you can just reply with the relevant snippet of code you are trying to use that would help to see what is going on.
Regards
Tim
> Run the working vector sample with:
> python test_project_standalone_no_wms.py
> Run the non working wms + vector sample with:
> python test_project_standalone.py
> I should miss something. Do you have any clue? It's a bug or a feature (unwanted for my case)?
> Cheers
> Thomas Gratier
> Qgis-user mailing list
Tim Sutton
QGIS Project Steering Committee Member
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151021/de3398f8/attachment.html>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151021/de3398f8/attachment.tiff>
