[Qgis-user] Removing artifacts in a created DEM
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Oct 18 20:19:22 PDT 2015
I would go with the TIN if your points are far apart. That will not create the bumps that you see. IDW is good but you may have to change the IDW weights from 2 (1\2, the typical gravity model) to 3 or 4 to smooth thing out. Be careful and make sure you original values don't shift too much. NN is very good if you have a very high density of sampling points (like LiDAR), at least in regards to the way it is implemented by GDAL.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Oct 17, 2015 03:29, "Andreas Neumann [via OSGeo.org] " <ml-node+s1560n5230817h88 at n6.nabble.com> wrote:
Hi Hernan,
I think neither of the methods you used give good results for
interpolating terrain data (or most other interpolations).
I had good results with v.surf.rst (available in the Processing
toolbox in the GRASS section). There are tons of options with the
v.surf.rst - but the defaults probably work for most options. You
also don't have to output all the raster results - just the
interpolated surface.
One of the other options is the "Interpolation plugin" which comes
with QGIS (but you have to enable it in QGIS). It appears in the
raster menu in as "Interpolation". It offers a TIN interpolation and
IDW. I think the TIN method is the more interesting one.
Hope this helps,
Andreas
On 17.10.2015 00:21, hersala wrote:
Hello,
I'm working with a bundle of N-S and E-W distributed DGPS
point transects on gentle glacier slope. With these points I
created a shp file and then I obtained several DEMs (.tif
files) using the tool Raster/Analysis/Grid (Interpolation).
I've used Nearest Neighbor, Runing Means and Inverse
Distance with several argument values. Inverse Distance
produces the best results, but there are some artifacts that
persists and makes the output unusable. They give the
impression as if the glacial slope has bumps, but on the
contrary, it is quite gentle.
Can anyone give any advice in how to proceed to reduce such
artifacts.
I'm using QGIS 2.8.2-Wien in MS-Windows.
Thanks in advance.
Hernan
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Removing-artifacts-in-a-created-DEM-tp5230769p5230817.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Removing-artifacts-in-a-created-DEM-tp5230769p5231017.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151018/0665410c/attachment-0001.html>
