[Qgis-user] Copy field definitions from one vector layer to	another?
    Joris Hintjens
    jorishin at gmail.com
    Mon Oct 19 12:44:47 PDT 2015
I’d try “join layers” if they are the same geometry type
Joris
> Op 17-okt.-2015, om 11:40 heeft Luca Lanteri <mescal72 at gmail.com> het volgende geschreven:
> You can make a join and then save as layer
> I have been looking for a capability (plugin or native QGIS) that will easily copy the field definitions (not the attribute data) from one layer to another layer.   To date I have not found it, I may be missing something obvious.  Any help/advice much appreciated.
> I have a layer with a bunch of fields already defined, and another layer with geometry but no additional fields.   I would like to add the field definitions from the first layer to the second layer, and then populate with the appropriate data for that layer.
> Thanks.
> Dick Males
> Cincinnati, Ohio, USA
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151019/d190531f/attachment.html>
