[Qgis-user] Copy field definitions from one vector layer to another?
Luca Lanteri
mescal72 at gmail.com
Mon Oct 19 23:21:05 PDT 2015
why do you need the same geometry type in order to make a join ?
You just need one common field.
Luca
2015-10-19 21:44 GMT+02:00 Joris Hintjens <jorishin at gmail.com>:
> I’d try “join layers” if they are the same geometry type
> Joris
> Op 17-okt.-2015, om 11:40 heeft Luca Lanteri <mescal72 at gmail.com> het
> volgende geschreven:
> You can make a join and then save as layer
> I have been looking for a capability (plugin or native QGIS) that will
> easily copy the field definitions (not the attribute data) from one layer
> to another layer. To date I have not found it, I may be missing something
> obvious. Any help/advice much appreciated.
> I have a layer with a bunch of fields already defined, and another layer
> with geometry but no additional fields. I would like to add the field
> definitions from the first layer to the second layer, and then populate
> with the appropriate data for that layer.
> Thanks.
> Dick Males
> Cincinnati, Ohio, USA
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151020/6bb79e8e/attachment.html>
