[Qgis-user] repeat image on every page in print composer
Alexandre Neto
senhor.neto at gmail.com
Tue Oct 20 10:35:31 PDT 2015
It's in 2.11 (master in current development)
A 16h11 Ter, 20 de Out de 2015, Joris Hintjens <jorishin at gmail.com>
escreveu:
> Hello Alexander,
> This feature is since cevesion 2.10? I am still working with 2.8
> greets
> joris
> Op 20-okt.-2015, om 12:44 heeft Alexandre Neto <senhor.neto at gmail.com>
> het volgende geschreven:
> Hi,
> I haven't really test it, but there is now a new functionality (created
> by Nyall) in master, that will allow us to control which layers (or
> preset) to show in the print composer.
> I believe that with the right coverage layer (a combination between the
> features normaly used in atlas and all presets names or layers list to
> cycle), It will be possible to use one single page to create the all the
> needed maps for each feature.
> Not sure if I explained myself... :-P
> Alexandre Neto
> Andreas Neumann <a.neumann at carto.net> escreveu no dia ter, 20/10/2015 às
> 08:27:
>> Hi Joris,
>> Actually there are plans to create a report generator in one of the
>> upcoming QGIS versions. Nyall Dawson works on this.
>> But the ability to repeat an item on every page could go into QGIS
>> before that - e.g. the next version. It could go into the general
>> "Rendering properties" of a print composer item.
>> You can ask Nyall Dawson about a quote - if you need this.
>> Andreas
>> On 19.10.2015 21:43, Joris Hintjens wrote:
>> > Hello Andreas, thanks for your comment.
>> > actually, I am working on a large report where I will have to make
>> several pages (+/- 10: a page for each layer in my project) and multiply
>> them again with the atlas generator. (times 50!) I hope it will work out …
>> > I found your work-around this afternoon, studying basic HTML since
>> supper now…
>> > Joris
>> >> Op 19-okt.-2015, om 21:30 heeft Andreas Neumann <a.neumann at carto.net>
>> >> Hi Joris,
>> >> Currently, only the HTML item has a "Repeat on every page" option. So
>> - as your workaround you could write a very small HTML, which references an
>> image.
>> >> I agree, an option to repeat an item on every page would be useful for
>> any element - e.g. labels, image, etc.
>> >> If you talk about Atlas context - of course all the elements in the
>> Atlas template would repeat on every page ...
>> >> Andreas
>> >> On 19.10.2015 21:07, Joris Hintjens wrote:
>> >>> Hi,
>> >>> I am looking fo a way to repeat a logo on every page in a multi-page
>> print layout (that is: another way than repeating the layout manually for
>> every page). No info on the tutorials and mailing list archive found.
>> Thanks for any comment
>> >>> Joris
>> >>> _______________________________________________
>> >>> Qgis-user mailing list
>> >>> Qgis-user at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151020/d1acb93f/attachment.html>
