[Qgis-user] repeat image on every page in print composer
Joris Hintjens jorishin at gmail.com
Tue Oct 20 08:11:24 PDT 2015
Hello Alexander,
This feature is since cevesion 2.10? I am still working with 2.8
greets
joris
> Op 20-okt.-2015, om 12:44 heeft Alexandre Neto <senhor.neto at gmail.com> het volgende geschreven:
> Hi,
> I haven't really test it, but there is now a new functionality (created by  Nyall) in master, that will allow us to control which layers (or preset) to show in the print composer.
> I believe that with the right coverage layer (a combination between the features normaly used in atlas and all presets names or layers list to cycle), It will be possible to use one single page to create the all the needed maps for each feature.
> Not sure if I explained myself... :-P
> Alexandre Neto
> Andreas Neumann <a.neumann at carto.net <mailto:a.neumann at carto.net>> escreveu no dia ter, 20/10/2015 às 08:27:
> Hi Joris,
> Actually there are plans to create a report generator in one of the
> upcoming QGIS versions. Nyall Dawson works on this.
> But the ability to repeat an item on every page could go into QGIS
> before that - e.g. the next version. It could go into the general
> "Rendering properties" of a print composer item.
> You can ask Nyall Dawson about a quote - if you need this.
> Andreas
> On 19.10.2015 21:43, Joris Hintjens wrote:
> > Hello Andreas, thanks for your comment.
> > actually, I am working on a large report where I will have to make several pages (+/- 10: a page for each layer in my project) and multiply them again with the atlas generator. (times 50!) I hope it will work out …
> > I found your work-around this afternoon, studying basic HTML since supper  now…
> > Joris
> >> Op 19-okt.-2015, om 21:30 heeft Andreas Neumann <a.neumann at carto.net <mailto:a.neumann at carto.net>> het volgende geschreven:
> >> Hi Joris,
> >> Currently, only the HTML item has a "Repeat on every page" option. So - as your workaround you could write a very small HTML, which references an image.
> >> I agree, an option to repeat an item on every page would be useful for any element - e.g. labels, image, etc.
> >> If you talk about Atlas context - of course all the elements in the Atlas template would repeat on every page ...
> >> Andreas
> >> On 19.10.2015 21:07, Joris Hintjens wrote:
> >>> Hi,
> >>> I am looking fo a way to repeat a logo on every page in a multi-page print layout (that is: another way than repeating the layout manually for every page). No info on the tutorials and mailing list archive found. Thanks for any comment
> >>> Joris
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151020/4308ee06/attachment.html>
