[Qgis-user] repeat image on every page in print composer
    Andreas Neumann
    a.neumann at carto.net
    Tue Oct 20 04:11:00 PDT 2015
Yes - that is in master. One can now select which layers or visibility
presets should be chosen (data-defined).
I used this to generate an Atlas over each administrative unit and for
each administrative unit a time-series (iterating over historic maps
from different years). Works fine, if your coverage layer contains
combinations of extent and time. I used a Postgis view with joins for
creating that coverage layer.
Andreas
On 20.10.2015 12:44, Alexandre Neto wrote:
> Hi,
> I haven't really test it, but there is now a new functionality
> (created by  Nyall) in master, that will allow us to control which
> layers (or preset) to show in the print composer.
> I believe that with the right coverage layer (a combination between
> the features normaly used in atlas and all presets names or layers
> list to cycle), It will be possible to use one single page to create
> the all the needed maps for each feature.
> Not sure if I explained myself... :-P
> Alexandre Neto
> Andreas Neumann <a.neumann at carto.net <mailto:a.neumann at carto.net>>
> escreveu no dia ter, 20/10/2015 às 08:27:
>     Hi Joris,
>     Actually there are plans to create a report generator in one of the
>     upcoming QGIS versions. Nyall Dawson works on this.
>     But the ability to repeat an item on every page could go into QGIS
>     before that - e.g. the next version. It could go into the general
>     "Rendering properties" of a print composer item.
>     You can ask Nyall Dawson about a quote - if you need this.
>     Andreas
>     On 19.10.2015 21:43, Joris Hintjens wrote:
>     > Hello Andreas, thanks for your comment.
>     > actually, I am working on a large report where I will have to
>     make several pages (+/- 10: a page for each layer in my project)
>     and multiply them again with the atlas generator. (times 50!) I
>     hope it will work out …
>     > I found your work-around this afternoon, studying basic HTML
>     since supper  now…
>     > Joris
>     >> Op 19-okt.-2015, om 21:30 heeft Andreas Neumann
>     <a.neumann at carto.net <mailto:a.neumann at carto.net>> het volgende
>     geschreven:
>     >> Hi Joris,
>     >> Currently, only the HTML item has a "Repeat on every page"
>     option. So - as your workaround you could write a very small HTML,
>     which references an image.
>     >> I agree, an option to repeat an item on every page would be
>     useful for any element - e.g. labels, image, etc.
>     >> If you talk about Atlas context - of course all the elements in
>     the Atlas template would repeat on every page ...
>     >> Andreas
>     >> On 19.10.2015 21:07, Joris Hintjens wrote:
>     >>> Hi,
>     >>> I am looking fo a way to repeat a logo on every page in a
>     multi-page print layout (that is: another way than repeating the
>     layout manually for every page). No info on the tutorials and
>     mailing list archive found. Thanks for any comment
>     >>> Joris
>     >>> _______________________________________________
>     >>> Qgis-user mailing list
>     >>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151020/b233099e/attachment.html>
