[Qgis-user] Debian jessie - QGIS 2.10.1 'Pisa' - can't find srs.db - reg.
Jaisen Nedumpala
jaisuvyas at gmail.com
Wed Oct 21 22:19:07 PDT 2015
Hai,
Debian jessie - QGIS 2.10.1 'Pisa' - Can't find
/usr/share/qgis/resources/qgis.db.
It is a matter of urgent. Need help. After an upgrade, when tried to change
CRS of a shapefile, it is found that no coordinate reference systems are
listed there in the Coordinate Reference System selector dialogue box.
Further investigation with log messages revealed that the file is not there
in path.
I have searched for the file to fix it temporarily by manually copying it,
couldn't find it anywhere. Please help me..!
Copy pasting the log messages here:
General:
2015-10-22T10:34:35 0 QGIS starting...
2015-10-22T10:34:36 0 Python support ENABLED :-)
2015-10-22T10:34:40 0 Application state:
QGIS_PREFIX_PATH env var:
Prefix: /usr
Plugin Path: /usr/lib/qgis/plugins
Package Data Path: /usr/share/qgis
Active Theme Name: default
Active Theme Path: :/images/themes/default/
Default Theme Path: :/images/themes/default/
SVG Search Paths: /usr/share/qgis/svg/
/home/jaisen/.qgis2//svg/
User DB Path: /usr/share/qgis/resources/qgis.db
2015-10-22T10:34:40 0 QGIS Ready!
Python warning:
2015-10-22T10:34:38 1
warning:/home/jaisen/.qgis2/python/plugins/TileMapScaleLevels/tilemapscaleplugin.py:72:
DeprecationWarning: QgsMapCanvas.mapRenderer() is deprecated
self.projection = self.canvas.mapRenderer().destinationCrs()
traceback: File "<string>", line 1, in <module>
File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 228, in
startPlugin
plugins[packageName].initGui()
Processing:
2015-10-22T10:34:39 2 Problem with SAGA installation: SAGA was not found or
is not correctly installed
CRS
2015-10-22T10:43:35 1 Could not open CRS database
/usr/share/qgis/resources/srs.db
Error(14): unable to open database file
2015-10-22T10:43:49 1 Could not open CRS database
- ജയ്സെനോവ് നെടുമ്പാലോവിച്ച് പഹയനോവ്സ്കി -
«´¨`·* . Jaisenov. *..´¨`»
( `v´ )
`v´
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151022/2d36b2be/attachment.html>
